Author Topic: 69 Water Pump Numbers  (Read 8081 times)
oneZ11
« on: October 03, 2012, 03:06:34 PM »
Need some help verifying casting and date numbers on a water pump. 1969 350/300hp. I found one to purchase, but want to make sure it's correct for this year and motor. Here's the numbers:
Casting:  3953692
Date:    A  26  0
Above Casting Number:  GM16
My original motor is first week of March, so this date code is plausible...
Re: 69 Water Pump Numbers
« Reply #1 on: October 03, 2012, 03:43:39 PM »
Quote
Casting:  3953692
Date:    A  26  0
That's the one, but unless you made a typo, that's a January 26, 1970 pump. Way too late for your car.
oneZ11
« Reply #2 on: October 03, 2012, 03:47:46 PM »
Mmmm... I called the guy to confirm. Attached is a photo of the casting number area. The "0" in the date code looks like a "C", but it wouldn't be a letter, correct?  (Sorry for the quality of the photo).
« Reply #3 on: October 03, 2012, 03:51:16 PM »
Yeah, that's a 1970 pump.
oneZ11
« Reply #4 on: October 03, 2012, 04:10:43 PM »
Bummer, but you're right. Thanks Ed for the confirm...
crobjones2
« Reply #5 on: October 06, 2012, 09:54:23 AM »
Where was your motor built? Tonawanda? if so, take a look at the 170 water pumps as well. They may be "more correct" for your motor
Chris
69 SS 350
opelitis1
« Reply #6 on: October 21, 2012, 10:58:30 AM »
Did you find a "170" in your date range yet?  Believe I have one dated A30 9   . .
Ted
oneZ11
« Reply #7 on: November 19, 2012, 04:07:33 PM »
Hi Ted. I'm sorry for not checking back with this thread. What do you mean by "170" ?  Is that a casting number?
If correct for '69, I might be interested.
crobjones2
« Reply #8 on: November 19, 2012, 05:55:57 PM »
yes "170" is the last three of the casting number. 3927170. I believe it is the correct water pump for a Tonawanda built 350/300. It was interchangable with the 3953692. The 170 has a T cast into it.
Chris
69 SS 350
srode
« Reply #9 on: November 29, 2012, 11:11:28 AM »
FWIW, my original pump is a 692
