Author Topic: VIN on a Powerglide  (Read 14088 times)
Petes L48
Re: VIN on a Powerglide
« Reply #15 on: November 16, 2012, 07:29:14 PM »
Good info to know, never thought of that.  It may take awhile to find a pan, I've been looking for a long time with no luck.  You may have to buy an entire tranny to get the pan you need.
vtfb68
« Reply #16 on: November 18, 2012, 06:19:31 PM »
Matt,
 Your original post says that your PG had a manual valve body, your later post (14) says that the valve body is properly dated to your car, So this transmission would be a Torque-drive (MB1) would it not? I thought those only came with standard six cylinder engines (no vin's on trannys).
   VT
68 08E LA RS Y2 749 L30 M35
upscope757
  • Almost there...
« Reply #17 on: November 18, 2012, 11:04:38 PM »
VT,
I suppose that is another option.  What looked like a manual valve body may have been a malfunctioning one. The tranny has been pulled a couple of times. Most recently we had it rebuilt with a 2,500 stall and shift kit.  When we had it running for the first time since '87, she didn't shift automatically.  The guy that rebuilt it built a second valve body for us.  In replacing it, we found the dates on the valve body in it. Indications are that it was run pretty hard in Montana in the 80's, lots of frame bouncing, etc... Original oil pan had been damaged and rewelded, likely had the tranny pan also replaced with a 70 pan at the time.
Matt
Matt: 1967 RS/SS - L48/Powerglide - Sierra Fawn/Beige Vinyl Top, Charleston, SC
upscope757
  • Almost there...
« Reply #18 on: November 18, 2012, 11:06:16 PM »
Trim Tag
