Author Topic: are cowl and trim tags painted  (Read 88624 times)
Mark
Re: are cowl and trim tags painted
« Reply #45 on: April 13, 2013, 05:17:36 PM »
So your saying there was a way to order a 69 Camaro without an engine, or was this just the guys at the plant getting together to make a car minus the engine?
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #46 on: April 13, 2013, 10:08:23 PM »
I got curious because I remembered seeing several white tags in my 68 database, so I went back and checked, and sure enough, I have several early 68 Norwood tags that are painited white. A few are even black, but with white underneath! Here are two examples. The top on is white and the bottom one is white under the black.
ZLP955
« Reply #47 on: April 13, 2013, 10:22:07 PM »
Oh John,
Help me out here... I have copies of the personnel records from Norwood.. Your name does not appear anyplace... Can you elaborate when you worked at Norwood?
I have been an interested spectator so far on this thread, but cannot believe the above post. Nobody has done more to share knowledge and insight with this community than JohnZ.
Tim in Australia.
1968 Z28
« Reply #48 on: April 13, 2013, 10:37:36 PM »
Oh John,
I think that you will find that John Hinkley (aka John Z) didn't work on the assembly line at Norwood.....he was the plant manager at one time.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #49 on: April 13, 2013, 11:46:14 PM »
Oh John,
I'm at a total loss at what your trying to accomplish but you just blew it big time!  John Hinkley (aka JohnZ) is a highly respected person who has consistently assisted with information to so many car enthusiast for many years through many forums and NCRS, and was enshrined in the the Corvette hall of fame a few years ago. You had a thing going back and forth with primarily one member but unfortunately your know it all, read my book, phone call away, etc. has pretty much alienated the rest of us with your negative and improper come backs.
tar6569
« Reply #50 on: April 14, 2013, 12:59:47 AM »
It was production related. And to see it , however because the workers resisted the new computer generated  "body broadcast" print out so the trim tag containing the option content was sprayed white to make it easier to see major option content at a glance.
Norwood had used the broadcast sheets in previous years, including a very similar form in 66 with the Impalas.  I'm curious as to why the workers all of a sudden resisted the broadcast sheets in 67?  Also, the white on the cowl tag has been seen on 65/66 Chevy fullsize cars from Norwood so they didn't start that practice in 67.  Is the B body/Chevy II production at Norwood for 65/66 covered at all in the book?
Warren
1964-1970 fullsize Chevrolet research
festival
« Reply #51 on: April 14, 2013, 01:28:29 AM »
 Guys.. Why jump to conclusions ?? It is really a simple question that John should be able to answer. ;D
« Reply #52 on: April 14, 2013, 01:38:20 AM »
No, we're asking YOU. YOU wrote the book. YOU stared the rant. Why do you insist of side stepping the questions?? And don't say "buy the book" because so far what I've seen, your book has more holes in it than Swiss cheese.
If you can't defend your positions (and apparently you can't), then please don't keep spitting out the same old crud. You've lost most of your credibility already. You should probably keep quiet so as not to loose what little you have left.
festival
« Reply #53 on: April 14, 2013, 01:52:43 AM »
Wow I must be on a nerve... Sorry about that guys.  Now why cannot John just answer the question?  What is the problem here gentlemen?
I am not worried about credibility at this point for very well supported reasons. ;D
« Reply #54 on: April 14, 2013, 04:53:54 AM »
I received a great piece of advice early in my business career...
Never argue with a fool he will drag you down to his level.
« Reply #55 on: April 14, 2013, 12:50:14 PM »
Hi Ed,
  Interesting find for '68! As for the white under black tag, the one reason that comes to mind is maybe either the dealer or new owner blacked it out to eliminate the bright 'eye sore' from a free hand tag spray job. Is there black under the white if you clear paint off further? I suspect black will be there.
lakeholme
  • 68-12D L30/M35
« Reply #56 on: April 14, 2013, 02:35:13 PM »
And Ed is the second one 09C?
I've seen a few very early 68 tags with white paint, but the white paint had generally deterioriated.
« Reply #57 on: April 14, 2013, 05:18:02 PM »
Phil, the second tag is a 09C as you suspected.
Mike, I have several that have white paint under the black, so I don't think it was a "one off". Your theory could be good, but there's probably no way we'll ever know for sure.
Here's another one. Originally an Ash Gold car. Note the white under the flaking black on the surrounding firewall.
« Reply #58 on: April 14, 2013, 06:41:17 PM »
Oh John,
Somehow, in your never-ending quest for the truth, you apparently failed to check the visitor logbook from the front lobby desk where Chevrolet engineers signed in every day; you'll find my sign-ins in February and March, 1969, from the Chevrolet Pilot Line. Jim Seim, who contributed a TON of material for your book, will remember me, and my boss at the time from the Chevrolet Pilot Line (Jim Heise) was the Chief Inspector at Norwood.
« Reply #59 on: April 14, 2013, 07:30:42 PM »
festival
Where are these meetings and is anyone invited to attend?  Depending on the venue and my schedule I would be interested to hear what these guys have to say.
Oh, and it would be nice if you answered questions people asked you.
Nobody knows everything - but most of us are willing to learn.
