Author Topic: 68 z smog system  (Read 23715 times)
427-KING
Re: 68 z smog system
« Reply #15 on: September 30, 2012, 12:13:02 AM »
I have access to the vin,ill see what it is and post it...
427-KING
« Reply #16 on: September 30, 2012, 04:14:07 PM »
# 464xxx
427-KING
« Reply #17 on: September 30, 2012, 04:18:52 PM »
Built 1st day July according to the crg date  vs vin chart.
1968 Z28
« Reply #18 on: September 30, 2012, 09:12:47 PM »
Mine is 475xxx.  Three weeks or more with the wrong pulley???   Don't know if they ran out of the 522 or some yo-yo put on the first pulley he grabbed.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
HOT3O2
« Reply #19 on: September 30, 2012, 10:56:11 PM »
King,
What are the date codes on the Wittek hose clamps on your pump?
Thanks, Rick
Rick
69 RS/Z28
427-KING
« Reply #20 on: October 01, 2012, 12:32:36 AM »
 2/68
427-KING
« Reply #21 on: October 01, 2012, 12:36:58 AM »
date on belt 167 68
« Reply #22 on: October 01, 2012, 12:55:44 AM »
10B 68 Z with original shallow smog pulley.
I've seen others.
427-KING
« Reply #23 on: October 01, 2012, 04:50:29 AM »
I've seen others.........   The pulley does not have #116 on it, it is blank, it was on "backwards",and I looked on both sides.
1968 Z28
« Reply #24 on: October 01, 2012, 05:51:50 AM »
Never seen one blank..that is unusual.....my pulley does have the number #3927116 stamped on it.
By "backwards" do you mean the smooth side toward the pump...that seems to be what it appears in the photos.  Although the AIM states that the part number faces the pump, my original pulley had the part number facing toward the front and the smooth side facing the pump.
On my #116 pulley, there is a difference in diameter between the two sides.  The smooth side of the pulley has a slightly smaller diameter than the part number side.  Also there is about a 1/8" offset from centerline between the two sides.  Is this the same on your pulley?
Jerry G.
« Reply #26 on: January 21, 2013, 05:46:21 PM »
Oh, you thought he was trying to sell it? =)
427-KING
« Reply #27 on: January 21, 2013, 07:03:39 PM »
If you take a supply and demand class youll see that whenever you have items no one else has, you can ask whatever you want,and will eventually get it.  Last time i checked with the outfit everyone refers people to on this site they wanted 5500.00 ,but didnt have it in stock.......... So you can pay me 3850 direct, or buy mine for 5500 thru them. I suspect the 5500 route is less painful for some.
« Last Edit: January 21, 2013, 07:24:01 PM by 427-KING »
« Reply #28 on: January 21, 2013, 08:39:23 PM »
generally speaking, I would agree. I just prefer to sell items in my lifetime.
« Reply #29 on: January 21, 2013, 08:50:55 PM »
In my opinion, ebay is the pinnacle of supply and demand. List something on there that's rare with a $1.00 starting bid and NO reserve and after 7 days you'll find out exactly what the demand is!
