Author Topic: 3904391 or 3919840 rectangle closed port heads  (Read 17590 times)
68SSragtop
« on: November 04, 2005, 05:11:58 PM »
Can anyone direct me to a source for a pair of 3904391 or 3919840 rectangle closed port heads.  I am trying to put my 396 back together and the original heads are long gone.  I need a date code between H 14 7 and H 28 7 or as close as possible. Thanks for any info or help you can provide.
Leonard1
Re: 3904391 or 3919840 rectangle closed port heads
« Reply #1 on: November 04, 2005, 05:48:55 PM »
Try here
www.tracyperf.com/index.html
They have several dates available for those heads.
(DougD: fixed the link code)
« Last Edit: November 04, 2005, 07:25:58 PM by DougD »
Leonard1
« Reply #2 on: November 04, 2005, 05:50:14 PM »
That link didn't turn out clickable like I expected.  What did I do wrong?
Flowjoe
« Reply #3 on: November 04, 2005, 06:45:29 PM »
You didn't put the link between the bracketed HTML code,,,normally that would be invisible but now you can see it
DougD
  • Administrator
« Reply #4 on: November 04, 2005, 07:26:19 PM »
That's correct.  I fixed the post to correct the code and make it a clickable link.
Leonard1
« Reply #5 on: November 07, 2005, 03:40:03 PM »
