Author Topic: 1969 Power Steering Pump  (Read 2041 times)
hdptsr
« on: February 15, 2023, 05:41:36 PM »
Hello,
I have a 1969 Z10 350 with manual transmission, factory AC and Power Steering car.  It was a basket case and am trying to bolt everything back up to the motor.  The PS pump double pulley seems to be to far forward by about 1/4 inch.  I am using factory cradle bracket and support bracket form forward manifold to motor mount.  I know the pulleys are correct.  I bought a remanufactured PS pump Sagnaw style.  My question is the rounded banjo style PS pumps standard on the 1969 SB or the more square topped PS pump?  I have seen both for sale for 1969 SB.  What else could be causing the mis-alignment of pulleys?  The crank pulley is a 3 groove pulley.  Thanks for any help you can provide
