I have two speedometer cable questions. They are in reference to my '68 with a factory Saginaw four speed transmission.
1) Did all Saginaw transmissions have the two piece speedometer cable? I have the two piece cable and that's what the AIM pg. 322 (see photo below) shows for the Production Engine which I assume refers to the base 327 which I have. It's called out in View A in the upper left hand corner of the sheet.
What is confusing me is that Heartbeat City has the two piece cable but calls it out for a car with cruise control and/or a heavy duty 3 speed. They also show a one piece cable available for Saginaw transmissions. This doesn't jive with the AIM. I would tend to believe the AIM but I'm needing a new cable and want to be sure I am buying the right one.
2) Also in View A on sheet 322, it shows a clip on the floor board holding the speedometer cable but doesn't call out a part number for it. I can't find any such clip in the parts catalogs. I had a hole in that location on my original floor board so there might have been a clip there at one time. I have the same hole in my new repro floor board.....Does anyone know where you can get this clip?
Thanks Dave
