Recent Posts
Pages: 1 ... 5 6 [7] 8 9 10
61
Decoding/Numbers / Re: Part Number Stamp or Sticker on Wiper Motor Assy
« Last post by rich69rs on March 27, 2025, 04:35:34 PM »
Norwood, O1C, RS
Stamped numbers on end of motor:  5045605, Type E, 12v
Stamped wording on side of motor:  Delco Products, Rochester N.Y. USA  (Couldn't get a very good picture - brake booster is in the way - but you can make out "N.Y. USA" at the end of the stamping.
Richard
62
Restoration / Re: Introducing the "GILMORE" 1968 Z28
« Last post by 169INDY on March 27, 2025, 05:16:02 AM »
Tank associated - Filler GM Replated, Orig Gas Cap, Misc View Rear & Trunk.
63
« Last post by 169INDY on March 27, 2025, 05:13:41 AM »
Fuel-Gas Tank (Spectra Made in CA) Tern plated.  Restored Factory AC Delco 3/8" Fuel Pick up using Dorman Donor parts, ECS anti squeak pads, Anti Drum Pad, Repop Filler hose, Replated (*ZINC) 12/1967 Whittek tower clamps, Square tang Olive 3/8" spring clamps, Stamped 3/8" Hose, AMK Black Masking tape,
64
« Last post by 169INDY on March 27, 2025, 04:48:06 AM »
Thanks: DuWayne, Darrel, Joe & Maroman.
I have been making progress towards the July Target Finish Date & Coming out Party & Shows.
Joe, I used the AMK tubular rivets and Hanson Buck-Peening tooling to Set the rivets for the end brackets. After Blasting, Prime, Powder coating of course a bit of silver overspray from the grill painting also. The Brackets are marked with Big "C"'s on the back side.
More progress to post soon.
65
1969 - Orphans / Re: VIN 124379N565575, pretty sure I have your DZ block.
« Last post by KurtS on March 26, 2025, 06:54:21 PM »
I updated the title with the full VIN. :)
66
« Last post by KurtS on March 26, 2025, 06:43:12 PM »
Is the part # stamped on the end plate and/or on the sticker? Which Delco plant (see Chuck's picture above)?
Thanks!
68
General Discussion / Re: LA built Camaros rear leaf spring black paint
« Last post by Mike S on March 26, 2025, 01:50:24 PM »
 A past discussion on LOS spring and tank factory paint:   http://www.camaros.org/forum/index.php?topic=11984.15
I have a few pictures of my 67 LOS survivor in that thread.
Below is a picture from a past discussion of the same car w/396 engine mount bolts facing upwards. My 67 NOR car has them facing downwards.
Sounds like William was spot-on with his info about the car. :)
All Camaro (and cars) used DOT3 brake fluid. DOT4 is interchangeable with DOT3.
70
« Last post by DuWayne Ladner on March 25, 2025, 06:11:19 PM »
Absolutely awesome car Jim, and thank you for sharing so much and sharing with us on a great forum sponsored by CRG. Just waiting for the finish up and it being shown show time. God Bless.
