Camaro Research Group Discussion => Originality => Topic started by: Camie on June 20, 2008, 12:16:10 AM
Title: Correct clutch size and bell housing number
Post by: Camie on June 20, 2008, 12:16:10 AM
I just found this forum and I hope that someone can help me out.
I am restoring a 1967 SS-350 with a 4sp Muncie. The car was missing the bell housing and flywheel.
I am trying to keep the car as original as possible.
What is the correct number for the bell housing, and what flywheel and clutch size was corect for this car??
Title: Re: Correct clutch size and bell housing number
Post by: JohnZ on June 20, 2008, 02:51:40 PM
Parts book shows the 621 bellhousing (14" diameter 168-tooth flywheel and 11" clutch) used on 350's and 396's, with the 403 bellhousing (12-3/4" 153-tooth flywheel and 10.5" clutch) used on everything else in '67-'68.
Post by: Camie on June 20, 2008, 10:12:11 PM
THANKS!!
Post by: x77-69z28 on June 21, 2008, 04:43:34 PM
i am just putting the finifhing touches on my 67 rs/ss 350. it is the 11"621 bellhousing. i have the part number written down somewhere for the flywheel if you need it. let me know.
buddy
