Camaro Research Group Discussion => Restoration => Topic started by: GaryL on March 17, 2008, 11:11:34 PM
Title: Rear spoler installation and sealing
Post by: GaryL on March 17, 2008, 11:11:34 PM
What is the best method to seal the spoiler installtion? Rubber washers under the nuts? Strip caulk?
Title: Re: Rear spoler installation and sealing
Post by: Jonesy on March 21, 2008, 03:03:04 PM
Gary
I used strip caulk and dum dum or electrical sealing putty and have no problems.
I did not used rubber washers, just the factory setup.
Post by: GaryL on March 21, 2008, 03:13:23 PM
I put strip caulk under soft rubber washers on the front studs. Then a good amount of strip caulk on the front nut/washer to plug the hole from underneath. Nothing on the rear acorn nuts. I also used aluminum duct tape to cobver the emblem holes. Seems to be working after my water test.
