Camaro Research Group Discussion => Decoding/Numbers => Topic started by: ggtsvnv on July 19, 2024, 01:50:51 AM
Hi all,8
Does this trim tag look legitimate?
I think we have seen this one before.. William will probably know.. I thought it appeared somewhere here initially in a cleaner condition, then re-appeared a short time later with the scuff marks.
Thanks Boomer,
Does anyone know how to seach the previous thread? I've tried and don't 't come up with anything
Do you have the VIN?
No just that tag it's in an ebay listing. I know the rivets don't look correct, but the has had qhat looks to be extensive sheet metal work. So maybe it's been removed and put back on? It's an ebay listing.
285966309749
That's the ebay listing number if it helps.
Listing on eBay:
https://www.ebay.com/itm/285966309749?itmmeta=01J3F0AF5XSZYJBQMNFDBHQVF7&hash=item4294eb9975:g:hz0AAOSwF9BmmJpu&itmprp=enc%3AAQAJAAAA4OkY5PNgKAlkeUNZ5XUYw%2FTb2eq%2FaFlJ%2FVU7GNMhg78p7anz5c8HHtO7e%2BdfwjyfvFb2L2zaDrggKfWa8Q6KjYvRHGeQ%2BReOUOpdSGPEwkiBVOfpAE0IEXaTQMTJIaIUAR9y3c5AmLova1mqKSOp8ggBVIRgtOomRlea9Pa0XA9JIbWbgEFj%2B1ioF2DM3LArlfzFOlomvUlfM3bOj7BlbKPfSdNW43TtDj0FFLwfE9L75YF6FeVLN59jAJNowx4vrJrZsMQUXpgKUzjgwgRoNNzEe84CSg8yuB8HsF04MGl6%7Ctkp%3ABk9SR_zyqeCbZA
That cowl tag is absolutely 100% fake/reproduction.
NOR373528
would love to know the VIN on this
Ebay Seller ky_hack8 Caneyville, KY
Sold for $25,500 with no drive train!!!??? Ouch
If you look at the photos posted on eBay, there is no VIN tag present.
