Camaro Research Group Discussion => Restoration => Topic started by: JST69Z28 on May 02, 2024, 12:38:47 PM
Title: Muncie shift lever seal replacement
Post by: JST69Z28 on May 02, 2024, 12:38:47 PM
Can you replace Muncie shift lever seals (in the side cover) in the car or does the transmission need to come out?  Mine drip oil.  I could not find any previous posts on this.  Thanks.
Title: Re: Muncie shift lever seal replacement
Post by: Kelley W King on May 02, 2024, 02:46:13 PM
You can remove the side cover with the trans in the car and replace the seals. Not bad on a lift, but can be done with jackstands
Post by: GMAD_Van Nuys on May 02, 2024, 03:10:34 PM
There was a previous posting on CRG about replacing the side plate with the transmission still in the car:
http://www.camaros.org/forum/index.php?topic=15570.0
Post by: Kelley W King on May 03, 2024, 11:18:54 AM
It has been a long time since I did it, I may have rotated the trans when I did it.  It would be interesting to see a post after it is done. I did not see a reply by Mike on the other thread.
