Camaro Research Group Discussion => General Discussion => Topic started by: marriest on April 28, 2023, 10:43:43 AM
Title: HP - 396cu = 325,350,375 what changes?
Post by: marriest on April 28, 2023, 10:43:43 AM
What is changed to effect HP on the 396 Cu engine?  Cam, Carb, Lifters?
Just curious or is it something else?
Title: Re: HP - 396cu = 325,350,375 what changes?
Post by: boomer632 on April 28, 2023, 11:30:44 AM
Compression ratio, cams, lifters to name a few. I think the L78 375 got the hottest cam with solid lifters, 4 bolt mains, rectangular port heads and Holley 4346. Lesser HP got smaller cam, oval ports heads, different compression rations and Rochester QJ carb.
Post by: william on April 28, 2023, 11:31:08 AM
The '69 L35 325hp and L34 350hp engines are similar and shared block [2 bolt mains], head and intake castings. Both used oval port heads. The L34 had a higher performance hydraulic camshaft, different carb and distributor calibration. I believe it also had a forged steel crankshaft. Neither really a high-performance engine.
The L78 shared block and head architecture with the L34 & L35 but that's about it. Block, head and intake castings are different. Heads had rectangular ports, bigger valves. Block had 4-bolt mains. Intake manifold was aluminum and used a Holley 780 carb. High performance mechanical lifter camshaft. I believe it used different connecting rods.
Post by: Sauron327 on April 28, 2023, 12:15:36 PM
My friend has an L78 and just rebuilt the motor. Rectangular ports don't turn on until the pedal is mashed and higher RPM's. That is not the way he drives so he went with oval.
Post by: 169INDY on April 28, 2023, 05:12:30 PM
https://www.motortrend.com/how-to/chevrolet-lied-stone-stock-1969-l78-396-big-block-makes-50-hp-more-than-factory-rating?galleryimageid=71cc4068-9cda-461c-9c18-94d2679c4859
Post by: marriest on April 28, 2023, 07:21:24 PM
WOW! Great information!
What was the reasoning for building 3 different engines with the same block?
Just to have options or were the other reasons?
Post by: crossboss on April 28, 2023, 09:52:50 PM
FWIW, and as mentioned, the 'Oval Port' heads will be the better street engine bar none. Think LS5 VS LS6 454's.
Post by: 169INDY on April 28, 2023, 11:22:49 PM
^^ TBD^^ I am testing a L78 transplant for my L35 after 30 years.
I can tell you my first impressions on the STREET is the 396/375 is Pulling like gangbusters. & I am still in the first few miles.
Post by: MO on April 29, 2023, 05:02:25 AM
Could have been insurance driven. Could also have been that they were available across the brand which made easy options for higher profit. Could have been that their dad wouldn't let them have an L78, so they got the L34/35 and upgraded when he wasn't looking.
Post by: bcmiller on April 29, 2023, 05:57:53 PM
Generally true. Oval ports will perform better below 5k RPM. Take some 049 or 781 oval ports, add larger valve and a port job - then then will be equal to or better than rectangle port heads above 5k.
Post by: crossboss on April 30, 2023, 04:07:37 PM
Maybe correct. However, it will take time (RPM) for those big ports to work. The oval port car will be ahead of you off the line and through most of the race. Torque moves the car. Think Buick/Olds/Pontiac 455 VS 426 Hemi/Boss 429s. Believe me, I know all about big port engines...
Post by: DuWayne Ladner on April 30, 2023, 06:34:56 PM
Yes sir 169Indy, I as well am about to find out how a freshened L78 CE code punched out to .60 over, hyd roller, 3.73 gears is about to pull and sound and perform, this coming week hopefully. Freshly restored 9’ SS 396 L78, rec Sept 22’, but dropped a cyl in less than 30 miles driven. Been in engine resto last 7 months, and about to be rolling again. Now ya keep in mind, haven’t shared my full history, maybe touched on it on quite a few MARO groups on FB, but I have not driven my Camaro since about 1986. So yes 169INDY, I am stoked and once again I want to feel, hear, and slap me some 4- gears of my M-21. Ya know thunder under the butt and that, oh my, power pull, again. Thanks ya, God Bless.
Post by: 67nut on May 07, 2023, 07:02:08 PM
Along with the rectangular heads, the solid lifter cam isn't as street friendly as a hydraulic one. But up the RPM's................... and look out! There's something to be said though about the sound of a solid lifter cam that gives me goose bumps.
The difference between a hobby and insanity is about .001"
Post by: PHAT69AMX on July 21, 2023, 02:43:49 AM
Could be sanctioning body rules for what is legal for use in a given class of racing, such as NHRA Super Stock.  For a given carb, intake, etc to be legal it must be available on a minimum of 50 cars as factory built from what I understand, at least is was 50 units minimum in 1969.  Then any car could use those pieces and parts and still be legal.  Say a '69 ZL1, a person could build a "clone" and it would still be legal in NHRA Class using all the parts factory installed and sold on the (50) copo cars, even though it was not an actual ZL1.  That might be why the less-street-friendly L78 396 option.
Post by: Kelley W King on July 21, 2023, 11:32:21 AM
I have both a rectangle port L78 camaro and an oval port 396 as well. The valve size is more important than the port shape. If you put the large valves in an oval port it might pass a rectangle port on the street but not in stock condition. No bench racing here, real life experience. The L78 cam does need at least 355 or 373 gears to get going just like the Z28.
Post by: DuWayne Ladner on July 24, 2023, 06:22:16 PM
LOL, 169 Indy. It’s just the beginning with your L78, don’t think you’ll go back to the L34! My L78 completely re-done, and just now breaking in. Love to get on our 4-Lane state Hwy and let all the SUV’s pull up on me at about 85 mph and just stomp the pedal and high gear them to about 110 and stick my hand out my window and flag them to get some more! My L78 is 1 pulling hoss with 3.73 gears. Makes me go all the way back to 19 years old, lol, fixing to turn the big 7-0. Just a little testimonial!!!!!!!!!!!!
Post by: Delco115 on July 24, 2023, 11:24:26 PM
Quote
Good for you!!! No reason to NOT still feel like you're king of the highway!! That's just the natural order of thoughts.
Post by: sixt9x33rs on August 05, 2023, 01:10:05 PM
I own both too. My L78 is in a 69 Chevelle with 4.10's. Cruises docile until you hit it and that camshaft, heads, and gearing make for a fun badass ride, pulls very hard and wheel hops bad during a burnout, but that is probably a different story. My oval port car is a 67 Vette 427/390 HP. So probably not a good comparison because of the 427, but I kid around that this is my station wagon engine in my Vette. It idles lazily at 650 rpm's, but has a nice lope. It pulls extremely hard down low and I am not sure how it pulls above five grand. It is the original engine in the car and don't want to run the risk of grenading the engine. I once owned a L35 69 Convertible automatic car. The torque in that car was really nice because it had a 3.07 and was a great driving car.
