Camaro Research Group Discussion => General Discussion => Topic started by: abiddle on January 12, 2018, 10:46:09 PM
Title: 1969 space saver spare hook mount location?
Post by: abiddle on January 12, 2018, 10:46:09 PM
Was the location of the 69 coupe hook mount different between a standard spare and the space saver? I tried to replicate the instructions in the AIM, and its definitely not possible from where my hook mount exists. Does anyone have a picture of how the N65 is supposed to appear in a 69 coupe trunk? Is this why there were different trunk mats available for a camaro equipped with the space saver spare, because the cutout was in a different location?
I'm attaching a picture of my N65 displayed wrong Wrong WRONG. I imagine so few people will know its wrong, but now I know its wrong and it will bug me.
Another thing I noticed in the AIM, it shows the inflator canister nesting inside the wheel against the base. But maybe due to the canister retainer being too long, the canister doesn't nest inside the wheel. Anyone have an original retainer?
Title: Re: 1969 space saver spare hook mount location?
Post by: abiddle on January 12, 2018, 10:50:23 PM
At least my spoiler-less deck is finally correct with my rear antenna. No one likes it without the spoiler except me...
Post by: cam69aro on January 12, 2018, 10:56:35 PM
looks fine without the spoiler, dig the Scout next to your Camaro too. you have a sweet ride. sorry I can`t help on the spare hook location.
Post by: abiddle on January 12, 2018, 11:07:09 PM
Thanks Eldon, much appreciated. That's my 69 scout still work in progress. I figured once I get the camaro finished I would spend more time with the scout, but I seem to still be futzing around with the camaro.
Post by: ZLP955 on January 13, 2018, 12:32:53 AM
Looks great without the decklid spoiler, nice clean lines. Mine came with D80 originally, so that'll stay, but now that I am older I much prefer the understated look of a Camaro without F&R spoilers.
Now back to the spare: I recall when researching the length of the correct J-hook for my car, that there were different factory configurations for coupe, convertible, full-size and space-saver. Unfortunately I can't help with any hold-down bracket location dimensions.
However, a couple of observations on your picture (I realise you probably know all this):
1) I believe the spare wheel was intended to be placed upside-down in the trunk, i.e. with the valve stem pointing down - maybe this helps fit the inflator can?
2) Jack mast was to be installed on a diagonal angle, touching the passenger wheelhouse and the other end fitting in the angle bracket near the forward trunk center.
3) Tire should be touching the seatback and the passenger wheelhouse.
Post by: abiddle on January 13, 2018, 12:58:53 AM
Thanks Tm - yeah I tried all of that, and now it occurs to me that I should have taken a picture of how that looked. Placing the SSS back against the wheelhouse and the wall, the hook is not even close enough to reach even with the wheel properly face down. And the hook is way too far fwd and the shaft angle back toward the rear of the trunk if I tried to place the wheel properly is drastic - the shaft is not up and down, which is when it dawned on me that maybe the hook mount was located further back for an N65 car?
Thanks on the spoilerless deck appreciation. I knew camaro guys would get it, so I need to hang with a camaro crew.
Post by: x66 714 on January 13, 2018, 01:35:32 AM
I too like the no spoiler look. I guess I'm bored with belly button Camaro looks, spoilers, cowl hood.....Joe
Post by: BULLITT65 on January 13, 2018, 05:50:34 AM
Deck lid looks awesome!!!
Your car is now one of kind in my book. A beautiful Garnet Red SS with no spoilers. Spot a pic of your interior with that cool looking tachometer for us.
(BTW, I gotta say how nice that Red looks ... 8) )
I miss my red 69
Post by: abiddle on January 13, 2018, 02:28:09 PM
I'm a little disappointed Austin, I was waiting for you to flag the jack straps as incorrect for the N65...
For those that don't know the story about this tach, it was on the car when I bought it 15 yrs ago. I thought it was just junk, so I tore it out and threw it away - leaving screw holes in my dash carrier where the tach was mounted. After a few years I started to really get interested in originality, and discovered this tach was a 69 dealer accessory. So I had to buy another one to replace the one I threw in the trash. Well 3 actually, just so I could make a working whole one. Most expensive piece of junk ever, its pretty much useless. But it does light up and the needle moves.
Post by: m22mike on January 13, 2018, 03:15:13 PM
Not true, I love it. Spoilers are way overused
Post by: bcmiller on January 13, 2018, 07:59:10 PM
Car looks really good. Nice to see one without a rear spoiler.
Post by: KurtS on January 13, 2018, 09:46:48 PM
Re: the SSS. Ask on the Firebird forums. The normal spare was SSS. Optional was a full-size.
Post by: Boston14 on January 15, 2018, 05:01:43 PM
abiddle,  My car is a convertible, so the position of the jack may be different in a coupe. The jack in your picture seems to be positioned too low.  Here is a picture of my original spare decal.
Post by: Stingr69 on January 17, 2018, 01:37:47 PM
Coupe is different mast position from either of the Convert diagrams.  Coupe is at an angle.  OP - The space saver spare tire/jack stowage instruction decal is different than than the regular full size spare instruction decal. See UPC N65.
BTW - The AIM UPC-10 for a convert jack stowage looks rather different than your picture.  Maybe your sticker is early vs AIM being late?
Post by: Boston14 on January 17, 2018, 11:01:26 PM
My 1969 car is an early car, 11D of 1968.  The AIM UPC -10 is for a full sized spare, not space saver.  The AIM picture for convertible with N65 (space saver spare top of page 407) is very close to my original Jacking Instructions in the above picture.
Post by: Stingr69 on January 18, 2018, 01:40:59 PM
Right, see it now.
Post by: gary on December 28, 2024, 03:56:18 AM
Anybody know if the J-hook for 1969 RS-Z/28 with VE3 bumper a different length than one with chrome bumper? Can anybody tell me the correct length of it? Thanks for any and all your help. Gary
Post by: x66 714 on January 06, 2025, 04:00:57 PM
The "J" hook would be different because of the wheel width, not the type of bumper....Joe
Post by: KurtS on January 08, 2025, 02:25:50 AM
Gary,
Please start a new thread next time instead of posting on a 6 year old thread on a different topic.
Thanks!
Post by: Badshifter on January 20, 2025, 06:18:11 AM
Late to the part but…..
Post by: abiddle on January 28, 2025, 08:27:36 PM
I like it but its not the correct wheel.
