Camaro Research Group Discussion => Maintenance => Topic started by: Mr 396 on October 16, 2014, 01:20:23 AM
Title: Heater Core
Post by: Mr 396 on October 16, 2014, 01:20:23 AM
Need to replace the heater core in a 68. Inner fender is already out. Question is, can the removal and replacement of a new heater core be done with out accessing the the heater box from the inside?
Title: Re: Heater Core
Post by: 1968RSZ28 on October 16, 2014, 01:33:59 AM
Yes.
Post by: Mr 396 on October 16, 2014, 03:18:48 AM
Any suggestions or is it pretty straight forward? Replaced one on a big block Nova from the engine side awhile back and it was simple. Was not sure about a small block.
Post by: L78 steve on November 03, 2014, 05:26:56 PM
Heater core should  be pulled from inside.  You may also consider replacing the foam facing on the doors.
