Camaro Research Group Discussion => General Discussion => Topic started by: DyRally-Z1986 on September 23, 2013, 04:58:46 PM
Title: Rotisserie
Post by: DyRally-Z1986 on September 23, 2013, 04:58:46 PM
Does anyone have a rotisserie they are done with? I have been constantly checking Craigslist with no luck and looked on the internet and not sure of which one to exactly go with. Every manufacturer states theirs is better than the other. Let me know if anyone has any suggestions of has one they are done with.
Thanks Tommy
Title: Re: Rotisserie
Post by: 69Z28-RS on September 23, 2013, 05:22:57 PM
you could make your own, build what you need for your car, and practice up on the welding at the same time.. :)
Post by: elcamino72 on September 23, 2013, 06:16:22 PM
I have one by accessible systems in Tennessee, I love it.
http://www.accessiblesystems.com/
Post by: DyRally-Z1986 on September 23, 2013, 06:23:59 PM
Which one did you purchase from accessible systems? Thats who I might go with if I cant find a used one.
Post by: 69Z28-RS on September 23, 2013, 06:46:59 PM
Here's one for sale on Craig's List.. Nashville, TN area..  $600
http://nashville.craigslist.org/pts/3942713474.html
Post by: elcamino72 on September 24, 2013, 03:34:01 PM
I have the Bottoms Up Lift 1500lb capacity car rotisserie with the pneumatic tire option.  The only change I would make would be to find a way to mount the rear of the vehicle solid instead of through the rubber in the rear spring mount.  I would probably make bushings out to aluminum to fit in there.
Post by: DyRally-Z1986 on September 24, 2013, 06:27:49 PM
So you didn't mount to your tail pan?
Post by: elcamino72 on September 24, 2013, 08:25:58 PM
No, I used these - http://www.accessiblesystems.com/bul/brackets/bracketsd04.php
Post by: BillOhio on September 25, 2013, 02:16:09 AM
I used the same one with brackets and both seta of tires. Could take a john Deere gator and pull around the driveway. Worked fine.
Post by: DyRally-Z1986 on September 25, 2013, 05:57:52 PM
What did you guys do for the front? Attach to the subframe or firewall? And did you have to buy additional brackets for the front? Thanks for the help!
Post by: 69Z28-RS on September 25, 2013, 06:37:27 PM
If you are going that far (rotisserie frame off), then you should remove the subframe for restoring independently which also reduces the load on your rotisserie support.   Attach to the same points on the body that the subframe attaches to, and the large nutserts at the top of the firewall (for the fenders)..
Post by: BillOhio on September 26, 2013, 03:28:28 AM
I had subframe out
Post by: BillOhio on September 26, 2013, 03:33:18 AM
Front
Post by: BillOhio on September 26, 2013, 03:34:43 AM
My buddy Ron helped.me
Post by: ggtsvnv on September 26, 2013, 09:43:51 PM
  I have been looking for one also. This is the one that I'm close to ordering but have not yet.
http://www.derekweaver.com/rodders-garage/auto-rotisserie/w-rotisserie/
It seems to come with a lot of extras and has good reviews.  Does anyone here have any experience with them? or know anything other than what the web site has on it?
Post by: DyRally-Z1986 on October 06, 2013, 06:41:58 PM
After a little bit of a battle we got the Z/28 up on the rotisserie. Now to figure out the balance bolts
(http://i1110.photobucket.com/albums/h443/tbryson117/image-4.jpg) (http://s1110.photobucket.com/user/tbryson117/media/image-4.jpg.html)
(http://i1110.photobucket.com/albums/h443/tbryson117/image-5.jpg) (http://s1110.photobucket.com/user/tbryson117/media/image-5.jpg.html)
(http://i1110.photobucket.com/albums/h443/tbryson117/image-6.jpg) (http://s1110.photobucket.com/user/tbryson117/media/image-6.jpg.html)
(http://i1110.photobucket.com/albums/h443/tbryson117/image-1.jpg) (http://s1110.photobucket.com/user/tbryson117/media/image-1.jpg.html)
Post by: Mike S on October 06, 2013, 07:12:26 PM
 That's one heck of a clean garage. Have you ever restored a car in there before?
The 69 looks good from the top. Does the bottom need much work to warrant a rotisserie?
Post by: DyRally-Z1986 on October 06, 2013, 08:07:53 PM
Never restored one in my garage, usually at my uncle's house. The garage gets cleaned regularly, I guess I have OCD.
Driver's rear floor pan. When I got the car it was just laid in there and had a few welds and they sealed her up with some good ol expanding foam. "Quality work in my opinion".
(http://i1110.photobucket.com/albums/h443/tbryson117/null_zps912cf7d0.jpg) (http://s1110.photobucket.com/user/tbryson117/media/null_zps912cf7d0.jpg.html)
Drivers toe board had a replacement toe baord just laid right on top of it till I pried it out in 5 mins.
(http://i1110.photobucket.com/albums/h443/tbryson117/null_zps085baa54.jpg) (http://s1110.photobucket.com/user/tbryson117/media/null_zps085baa54.jpg.html)
The best for last...The car has had quarters put on it and if you were to go to all that trouble why would you not replace the trunk fillers??
(http://i1110.photobucket.com/albums/h443/tbryson117/null_zps66270b1c.jpg) (http://s1110.photobucket.com/user/tbryson117/media/null_zps66270b1c.jpg.html)
(http://i1110.photobucket.com/albums/h443/tbryson117/null_zpsecc54394.jpg) (http://s1110.photobucket.com/user/tbryson117/media/null_zpsecc54394.jpg.html)
Coolest thing I found when cleaning out the interior
(http://i1110.photobucket.com/albums/h443/tbryson117/null_zps9cb57c7f.jpg) (http://s1110.photobucket.com/user/tbryson117/media/null_zps9cb57c7f.jpg.html)
Post by: z28z11 on October 07, 2013, 02:59:08 AM
Accessible systems ? Buy new or used ? Just curious - I've been thinking of springing for one for a few years. My old bones would sure appreciate the purchase (last session of dropping in a Muncie nearly put me in the hospital. Or at least, that was the "sympathy generating reasoning"). I just can't crawl around on the concrete like I used to -
Post by: DyRally-Z1986 on October 07, 2013, 10:20:37 AM
It is an accessible systems rotisserie. I ended up buying new after an unsuccessful search for a used one.
Post by: jdv69z on October 07, 2013, 01:44:16 PM
Boy does this sound familiar!!
Post by: x77-69z28 on October 08, 2013, 02:28:30 AM
And how! I will be buying one soon as well. Was looking at the autotwirler plus. Any thoughts?
