Camaro Research Group Discussion => Maintenance => Topic started by: KENSTOY1969 on July 26, 2006, 01:16:04 AM
My 69 blue dot stereo radio is only working on the left side. In reviewing an old wiring diagram for the radio there is a green and green/black wires coming out of the connector where the main power plugs into on the radio. Per the diagram these wires are supposed to go to a "stero adapter".
Does anyone have a diagram or can explain where these two wires connect?
Thats the power feed to the multiplex unit mounted up under the dash behind the glove box.
Mark - found above the glove box. Thanks. Going to replace the Delco DS-501 amplifier and see if that brings the channel alive.
By the way, with a steror radio is there a connection up to the speaker installed in the upper middle of the dash?
Dash speaker is not used (and not even installed) with a Multiplex radio. The multiplex radios used 2 kick panel and two rear deck speakers only.
